VDB 142 Elephant Trunk HOO
ebony star substitutes okay?
Started by toml, 02/27/2005 07:23PM
Posted 02/27/2005 07:23PM | Edited 02/27/2005 07:23PM Opening Post
Hi Gang.
I have read over and over about the wonderstuff called ebony star. Actuallly, I have a 2' square of it in my hands, but. My trunion arcs came out to 38" not 24" so even on the diagonal I can't cut one strip of ebony star for them.
Just as well, as I actually don't like the look of the faux granite (so very 80s kitchen home depot remodel looking ! wink from a purely aesthetic point of view, and I tend to LOOK at things from that point of view. Of course function is important too, primary in fact, but since I can't use the ebony star I was intending to use, I have to buy some more laminate, and if I have my druthers, I would rather get something pure black.
Can one really not deviate from the sanctity of ebony star? Can any similar textured pebbled laminate not work just as well. Yes I read the tests KB conduct in their book, yes I understand the friction/stiction issue, but the question is can other very similar laminates be used to equal effect? Is this blasphemy?
For reference, I am building a 13.1 dob with 19" diameter trunions one inch thick, with a 38" arc measurement each.
Thanks for your insights/experience.
TomL
Posted 02/27/2005 10:00PM #1
Hi Tom,
I use sheet teflon (.022" thick) glued to the ground board and running against teflon pads for several scopes. I think it's the perfect answer for all sized dobs.
It's available from most plastics supply companies. Ask for waste pieces from the rolls.
It's worth the hunt and extra time.
If your boards are perfectly flat. you can run two sheets of teflon together (both loose-no adhesive) without pads at all.
John
Posted 02/27/2005 10:02PM #2
Tom,
Ebony Star is of course the color scheme of the Wilson Art Formica and not the model, type of material. The color makes no difference. You can even use other pebbled surfaced materials from other manufacturers.
