first project, secondary questions...
Started by mary hofer, 06/23/2003 02:24PM
Posted 06/23/2003 02:24PM Opening Post
Well, I spent my anniversary at my the local telescope making workshop (it was okay, the husband had a gig...and I was so excited to start grinding-first time!). I wanted to go ahead and pre-order a Telekit kor the f/5 12.5" mirror I'm making (not too skilled carpentry-wise, thought I'd be better off with a kit), and they're asking me about secondary sizes. I see this was an issue here for a while. Randy at Astrosystems recommended a 2.6" secondary- do you agree? Any recommended sources for high quality secondaries?
Mary
Posted 06/23/2003 03:53PM #1
I had a 12.5"/f5.2 that I used a 2.5" diagonal and it worked very well. It was a case of already having the 2.5". Astrosystems had to make me a secondary holder for it as 2.5 is no longer a standard size. So, you may as well go with the 2.6" so the holder won't be an odd ball size.
Walt
Posted 06/23/2003 03:54PM #2
2.6 or 2.14 are the obvious choices. 2.6 would be "better for deep sky with a more fully illuminated field," and 2.14 "may give slightly better contrast for planetary viewing." There is a theory that central obstruction should be held to about 20% for best contrast, and 2.6 at 21% it pretty damn close. The 2.14 still looks good on the SEC program, and a 17% central obstruction. 2.6 is probably the more conservative all around use choice. But, I don't think that you could go too far wrong with either, and people do change there secondaries on occasion so it's not cast in stone.
