Iris Nebula
Focault tester slitless do I need it to tilt?
Started by kb4mxo, 05/22/2003 03:18AM
Posted 05/22/2003 03:18AM Opening Post
I am almost done with my tester. I was looking around on the web and some tilt. Do I need to make it tilt? I would like to make it double as a ronchi tester also. Can anyone tell me of a site that tells how to do that? I also added the picture of my tester. It has less than .001 inch slop in the rails. It repeats the reading perfect each time. So I think I have it working good enough now.
Thanks for all the help
Steve
kb4mxo's attachment for post 6225
Posted 05/22/2003 08:11AM #1
Steven You do need to be able to move the plateform in 2 dimensions. Towards and away from the mirror which you have and across the mirror side to side. Some testors use a tilt to create the side to side movement because only a small amount is needed. For the traditional ATM mirror test you do not need to measure this side to side travel it just needs to be movable. You might even be able to push the whole platform side to side manually if it was in a track that would keep it from sliding closer or farther from the mirror.
Good luck and post some more pictures when you are done.
P.S. If you will be using your eye and not a camera or web cam you might want to mount the slit hole closer to the edge so you can get your eye close to the "window" without your nose hitting the platform. My setup is just the same and I find myself turning my head sideways to get my eye closer to the slit and looking out the corner of my eye. I'm not sure but I think this changes the readings some.
Dave
Posted 05/22/2003 06:08PM #2
Thanks everyone for the help. I will add the adjustment to the tester. Yes I am using a spring as a return spring. And the rail really keeps side play down to basically nothing. I added a picture Bob of the spring setup. Looking for a weaker one when I get to a bigger city.
Thanks
Steve
kb4mxo's attachment for post 67662
