Mark Eby
M33 Triangulum Galaxy
Focuser Draw Tube in Upper Cage
Started by renegade, 01/16/2004 02:14AM
Posted 01/16/2004 02:14AM Opening Post
Hello,
I'm building a 12.5" truss tube dob using Kriege and Berry's book. According to their book, the inside diameter of the upper cage should be about 13 1/8". I've purchased a MoonLite crayford focuser. When the focuser is fully racked in the draw tube will extend about 1.5" into the upper cage. With a total of 2" of travel, the draw tube won't actually be out of the tube until the last 0.5" of travel. So, most of the time my eyepieces will come to focus with at least part of the tube protruding into the upper cage.
Will this be a problem i.e. will the tube block some of the light coming on to the primary? If so, how do I solve the problem? Just make the upper cage bigger? Are there negative consequences to making the upper cage bigger?
Thanks for your help.
Posted 01/16/2004 02:28AM #1
It could cause a spike in the optics, like a spider spike.
You could use piece of plywood or plastic as a spacer to raise the focuser. All that is needed is to figure that into the measurement for the hole for the focuser. It could be 1/2" or more thick. That would subtract the same amount in the focal length distance measurement made to determine the placement of the focuser hole.
1/2" would give you an equal distance in or out of the tube.
Remember that the focuser board is also above the tube, have you figured that in your measurements when determining this focus travel?
This is only one possiblity of course, others will have ideas I am sure.
Floyd
Posted 01/16/2004 03:04AM #2
I would have to question the 13 1/8" upper cage diameter. The program Newt or WinNewt says a tube diameter that size will vignette 75% of the ray at front aperture. The only reason this caught my eye is because I am also building a 12.5" truss. What is your focal ratio?
Here is the link to the software :
http://home.att.net/~dale.keller/atm/newtonians/newtsoft/newtsoft.htm
I would like to share some ideas, if you wouldn't mind. I am in the design phase.
- Tim Hornbeck
Posted 01/16/2004 03:45AM #3
Thanks Michael.
I have thought of using a 1/2" board instead of 1/4", which would give me a little more room. I will already be using a 2.6" secondary.
Is there any danger (besides extra weight) of making the upper cage around 14" to totally eliminate this problem?
Scott
