RICHARD COFER
focusing accuracy
Started by vlad, 11/04/2003 08:45PM
Posted 11/04/2003 08:45PM Opening Post
After it came to me how inefficient focusing can be with with faster telescopes and ordinary focusers, I figured why not to check it out. It appeared to be too bad, and my assumption that the least controlable movement is not much better than 1/100 of a full turn of the knob was just an out-of-head guess.
I cut out an 8" circle, had it attched to the knob of an ordinary 2" R&P, ordinary Crayford and an 1.25" helical.
I was in for a surprise. The smallest move I could repeat a few times measured ~1/4 mm for the R&P and ~1/3 mm for the other two. But it required near-zero backlash/slippage and near perfectly constant finger pressure (even small change in finger pressure would make it up to several times worse). A reasonable smallest controlable move (one that can be achieved most of the time) is probably somewhere around 1/2 mm on the edge of an 8" knob, and that comes down to less than 1/1000 of a full turn - 10 times better than I thought. It can be somewhat better than that but, also, if the focuser is too stiff, or too loose, or mechanically inferior, it can be considerable less precise.
This focusing precision allows approx. 1/6 wave smallest focusing increment at f/5, and four times less at f/10 for the R&P and Cryford. Fine for f/10, but needs better for fine focusing at f/5. Small helical is over half a dozen times more precise, because one full turn makes for les than 3mm travel (as opposed to 20+mm for the R&P and 20-mm Cryford).
These results match fairly well those that I came out for the SCT (it was easy with micrometric focuser), with the smallest controlable knob move also somewhat better than 1/1000 of a full turn. It translates into a less than 1/20 wave smallest focusing increment, which is adequate.
Even with the results as approximative as they are, the likely conclusion is that an R&P or Crayford w/o fine focusing still are not adequate for fast instruments, although not nearly as much as I thought. But they might be still good enough for apertures having ~1/3 wave, or more, of seeing error in 1 arcesec seeing (~12" and larger).
Posted 11/05/2003 01:55AM #1
Wow, Vladimir! This is very interesting. Does this mean we (I have an f/4.5 and and f/5 newt) should all get Feathertouch focusers? Sounds like trying to focus a fairly fast telescope is a "hit or miss" situation.
Also makes me wonder about all the telescope reviews saying that objects "snap" into focus.
Kevin Beebe
Posted 11/05/2003 03:50PM #2
Very interesting, Vlad, but the situation may not be all that bad for those of use with fast dobs. Typically, fast dobs are used for deep sky observing and also typically not at really high magnifications where you can see 1/6 or even 1/4 wave mis-focusing. At low to medium magnifications very slight mis-focusing of that order is not noticeable. Using your fast newt for planetary and/or close double splitting is another story, but that's the exception rather than the rule.
Still, I like my Moonlite dual-rate Crayford, as it is far superior to the old helical I put up with for more than 15 years on my 13". It makes focusing a "snap". grin
Best regards,
Doug Scobel
Posted 11/06/2003 04:35AM #3
>>> (quoted) >>>
The smallest move .... A reasonable smallest controlable move (one that can be achieved most of the time) is probably somewhere around 1/2 mm on the edge of an 8" knob, and that comes down to less than 1/1000 of a full turn ....
... Small helical is over half a dozen times more precise, because one full turn makes for les than 3mm travel ...
>>>>> (end quote) >>>>
YES abut the helical. But.... The 3mm per turn assumes 10 threads per 30mm.
Getting super fine 20 threads per inch (==> 25.4mm/20) yields 1.27mm per turn. My first experiment used a drain plug with 5 tpi and it worked beautifully with a 6" wheel using a guitar pick.
The guitar pick is a wonder. It's design is sooooo simple.
Super fine threads for a helical, an 8" wheel and a guitar pick. Perfect ???
The helical's focuser tube can be big, at least 2" or so for 1.25" EPs. Cut the adapters to solve the rough focusing issue.
Fine focus adjusts for expansion/contraction of the telescope tube (or trusses.)
