Folded Newtonian
Started by jjam47, 09/13/2012 04:57AM
Posted 09/13/2012 04:57AM Opening Post
Hello all,
I need a little help.I'm constructing a 16" truss style Dob.Primary dia. is 15.88" clear aperture.Focal ratio is 6.07.Focal length is 96.31".I'm a little concerned about truss length and stability.I saw some examples of folded newtonians and thought I might try that with mine.I was considering the single larger secondary design.I was curious as to how much shorter my truss poles would be using this design and trying to keep the secondary obstruction to a minimum.I'm good at building the scopes but not so much with the optical design.Can anybody help me with the numbers for this.Just need to try to take as much length away from truss tubes as possible and still get a decent image.Need secondary diameter,distance from primary,tilt angle etc.Thanks. -Joe-
Posted 09/13/2012 01:28PM #1
If you want to play with some numbers, an excellent tool is Mel Bartels' diagonal calculator (see http://www.bbastrodesigns.com/diagonal.htm). This doesn't specifically address tilted diagonals but you should be able to adapt the numbers to your design.
Personally, I wouldn't shorten the scope just to improve truss stability. If the poles vibrate, I've heard that you can reduce vibration by wrapping a strap around the entire truss at the middle (haven't tried it myself). Shortening the tube by a couple of inches, pushing the focus outward, might help if you plan to use a binoviewer which requires a lot of inward focus. It also will make it easier to reach the eyepiece at zenith. The cost is a slight loss of image contrast due to a larger diagonal.
Posted 09/18/2012 07:28PM #2
Is this what you are talking about?
Keith
klawson's attachment for post 145418
Scopejunkie
USAF Vet
