foucault tester
Started by BABOafrica, 07/25/2012 06:18AM
Posted 07/25/2012 06:18AM | Edited 07/25/2012 01:15PM Opening Post
I built a Foucault tester. Photos attached.
Is the telescope viewer supposed to be focused on the mirror that is being tested? Or on infinity?
From the picture, is there any way if you can tell me whether the slit for the light source is narrow enough?
I'm asking because I don't see any patterns like the ones in the book when testing a parabolic mirror. So, I must be doing something wrong.
Clears,
Joe
PS For the record: I can see the mirror darken when moving the knife edge into the field of view.
BABOafrica's attachment for post 55920
In lumine tuo videbimus lumen.
8O Home-made 10” Dob / Home-made 4” refractor
EPs: Konig 32mm (1.25") / Zhumell WF 30mm (2") / Nagler 13mm T1 / Orion Sirius Plossls 25 & 10mm / Zhumell Plossl 9 mm / Meade MA 9mm
Posted 07/25/2012 06:19AM #1
more pix
BABOafrica's attachment for post 144886
Posted 07/25/2012 01:37PM #2
Focus the scope on the mirror surface.
If you can see the shadow of the knife edge but not any patterns, you may not be close enough to the radius of curvature with the knife edge. Slide the assembly closer to the mirror or further back until you get the knife at the radius of curvature and the mirror darkens all over at once as you move the knife edge into the beam.. Then you should be able to make fine adjustments to see the patterns.
hope this helps,
dan
