james carter
North American Nebula NGC7000
Ground board. Ebony Star or Teflon?
Started by thornbe, 03/05/2004 02:23AM
Posted 03/05/2004 02:23AM Opening Post
Just wondering if it makes a difference on which surface the Ebony Star or Teflon is applied? I found a nice 16" x 19" piece of laminated counter material (not press board either) that I would like to use as my ground board. I would then attach the Magic Sliders or Teflon to the bottom of the rocker box. Would this be a problem?
Clear skies,
Tim H.
Posted 03/05/2004 03:22AM #1
The problem with that is that dust and dirt will collect on the surface of the ground board, and find its way between the laminate and the Teflon pads. It's better to have the Teflon pads on the ground board and the laminate on top to keep the bearings cleaner and hence smoother.
Doug
