VDB 142 Elephant Trunk HOO
Help me ... I am obsessed
Started by thornbe, 03/29/2004 03:37PM
Posted 03/29/2004 03:37PM Opening Post
While I was making coffee this morning, a thought came to mind that you could use large coffee cans connected together to make a tube. I actually went as far as measuring the diameter of the coffee can. It's ~6". Then I actually took our Pampered Chef can opener (the one that makes a very smooth cut) and opened up the bottom. The can has numerous ribs along the edges that make the can very rigid. You could actually use one of those Meade 4.5" mirrors and have a very unique scope. Very neat conversation piece at viewing sessions.
Anyone every do something like this?
- Tim H.
Posted 03/29/2004 06:24PM #1
I think someone may have done this. Check out the stellafane website if you're interested I think I remember someone having a tube made of coffee cans that turned out pretty well.
Rick Riley
Posted 03/31/2004 02:25AM #2
Timothy,
You mention a 'Meade 4.5 mirror' and 'unique' in the same sentence. On what grounds are you canning homemade optics?
(Sorry)
Drew
Posted 04/01/2004 03:08AM #3
I soldered three tomato-paste cans to make a primary baffle for my classical cassegrain. Sprayed the inside black. It's worked great for 24+ years. The lips of the cans extend into the light path only about 1/16" inch, so there isn't a great benefit with slightly off-axis light reflections.
Good luck.
Bob Schnitzer
Grenville Base Observatory - Haymarket, VA
http://www.grenville-observatory.com
16" f18 Royce Conical Dall-Kirkham
10" f16 Parks/Coulter/Novak/Cave Classical Cassegrain
127mm Orion Starmax Mak-Cas
80mm f15 Meade refractor
40mm Tasco variable power tabletop refractor
DMK 31AF03.AS
DBK 21AF04.AS
Posted 04/01/2004 07:17AM #4
We used to do this with cans from vegetables to make great potato/tennis ball guns. We even mounted them to our bike handlebars with hose clamps. I wouldn't recommend our duct taping method for supporting optics, though. This idea sounds cool and would make a great crowd grabber for sidewalk astronomy. Good luck.
Ken
Customized Zhumell Z12 on Dedicated Atomic EQ Platform
Customized Hybrid Z12/Lightbridge on Baltic Birch Planisphere Mount
(I'm holding famous Martian meteorite ALH84001 in the picture.)
Posted 04/01/2004 08:04PM #5
Better Hurry though because the new coffee cans are plastic. Yuck
Dave
