I am in the middle of building an 8" Dob. I am ready to paint the inside of the 10" Sonotube. It feels like it has a wax coating. Can I ignore this or do I need to clean it off? How? (I plan to use an alkyd base urethane flat black)
Help, Painting inside a Sonotube
Started by Allennewton, 06/03/2004 01:44AM
Posted 06/03/2004 01:44AM
Opening Post
Posted 06/03/2004 02:01AM
#1
You need to remove the wax coating or the paint will not stick. It is pretty easy to peel it out along with the first layer of paper it is coated on. Carefully, at the end of the tube, find the beginning of a spiral, and lift the first layer and carefully start pulling it off. As you get the full width coming up, it will have a tendency to tear, so slow down and pull carefully. Once you get it about halfway, stop and go to the other end and repeat the process from there.
Just be sure you are removing only the very first layer of material to preserve the strength of the tube. Once removed, the surface will have a "tooth" that looks like rough sandpaper. Leave it like that as it will aid the adhesion of the paint and will help breakup the light reflection as well.
I have had good luck painting with a high quality flat black latex paint. One of those small foam rollers and bending the roller handle so it is straight rather than a 90* angle also facilitates getting into the tube. Use a radial rolling pattern starting at the middle, working out toward you minimizes the mess. Go to the other end to finish.
See, that wasn't so hard, was it!!
Hope you enjoy your scope as much as you will enjoy building it!!
Walt
Walt
Posted 06/03/2004 01:31PM
#2
Carey, what Rick and Walter said. I would add what I’ve done with mine after peeling the waxy paper is to seal the inside surface with a couple coats of shellac to waterproof it. I observe in an area where dew can get really bad and it makes the now bare cardboard surface nearly impervious to moisture. I then follow up with Krylon ultra flat black spray. Also, be sure to seal any unfinished edges (like the hole for the focuser, or the ends of the tube) with shellac or waterproof carpenter’s glue. On the exterior of Sonotubes I have used Krylon’s polyurethane enamel with great results. After years of use and a lot of dew there’s no deterioration at all. You may have to shop around for it, or order it from a paint store tho.
Doug
Doug
Funding Member
