Hexagonal Star Test - Ideas??
Started by rnabholz, 08/01/2004 03:12PM
Posted 08/01/2004 03:12PM | Edited 08/01/2004 03:20PM Opening Post
I had a chance to get out with my newly reconfigured 13.1" scope last night ( http://www.indytel.com/~rnabholz/index.htm )and did some testing.
The star test is showing a clear hexagonal shape at high power and I could use your ideas as to how to diagnose the problem.
Some stats first.
13.1" f4.5 mirror
1 1/8th" thick
9 point cell as spec'd by Plop
3.1" secondary attached by silicone
Arguments in Favor of improper support by Cell
1. Thin Mirror, maybe 18 point would be a better choice?
2. Hexagonal Pattern suggests pattern that would result from 3 outer pad sets and 3 spaces between.
Arguments against improper support by cell
1. Previous Coulter Tail Gate cell was a 9 point with no observed problem.
Arguments in Favor of Secondary as cause
1. Silicone mounting could have stressed secondary
2. Previous Coulter mounting was 2.5" square double sided tape, Better support?
3. One of the 3 silicone pads shows concave sides instead of convex, Maybe the culprit?
Arguments against Secondary being the cause
1 Trouble visualizing how a secondary mounting with 3 pads would cause the hex pattern.
Well you have my thoughts, What do you think?
Thanks
Rod
Rod Nabholz
Home Built Astronomy Projects
http://www.homebuiltastronomy.com/
Wild Bird Photography
http://www.wildsideiowa.com
Posted 08/01/2004 03:53PM #1
Hi Rod
I'm a novice about mirrors, but is it possible that the mirror was not supported correctly during the refigure?
Buck
Posted 08/01/2004 08:26PM #2
Thanks for your thoughts Bill.
The scope uses a "two vane" V shaped spider configuration yielding an x shaped diffraction pattern.
I will check the clips, although they are positioned 1/8 to 1/4 inch above the mirror and don't hold the mirror down. I don't think it could be stressing the mirror, but anything is possible and I will take a look.
Thanks
Rod
Rod Nabholz
