Ghost of Cassiopeia
How can I specify a secondary for astrophotography
Started by moutinho, 07/15/2004 10:10PM
Posted 07/15/2004 10:10PM Opening Post
Hi,
I intend to build a 7"f/5 or 5"f/5 scope in order to make astrophotos. I would like to know how do I calculate the secondary size in order to use a 35mm camera. What about a vesta webcam ? The secondary specification is the same for both cameras ?
Andre
Posted 07/15/2004 11:47PM #1
As Rick has pointed out, NEWT will give you all the possibilities as you plug in the numbers.
Back in the 70's and 80's when I used to do a lot of film astrophotography. I used an 8" f/5 that I custom built for photography. It had a 2.14" scondary that gave about 75% illumination over a 35mm frame. In all honesty, I could barely see the falloff at the extreme corners, and if I cropped any at all, which was usual, there was no problem. A few years after building the scope I tries a 1.83 diagonal for some visual use, and ended up taking some photo's one night with the smaller diagonal. I could barely tell the difference.
The truth is that even very expensive camera lenses do not fully 100% cover the film plane at wide open aperture. I tend to think that we sometimes overrate the "fully illuminated fov" issue.
Walt
