A few years ago i got hold of a large quantity of rosin or pine resin.
I make up pitch by combining with stockholme tar which is used for dehorning cattle believe it or not.
A standard brew is a 7/1 ratio which I heated to melting point stirred and then put into little casts lined with foil.
I then end up with what looks like blocks of toffee which I wrap in tinfoil and store in a container. They can last for years in a cool place.
I take care to ensure they are the same thickness around 5-6mm.
I simply heat a knife over a candle and and cut them squares which are placed on a tool to form a lap.
I usually make a slightly softer brew for figuring tools which are subdiameter.
Pitch needs to be sealed and tends to harden is exposed to the air from my experience. By wrapping in foil and keeping in a sealed tin in a cool place it seems to stay fresh.
