I've got my two virtual counterweight springs working well, however I'm still a bit top heavy (all told, between my rings, the bino, and all the other stuff I'm about 25 lbs out of balance!). Where I end up loosing it is in the end ring, which is baltic birch and as heavy as can be. It's probably 2-3 pounds, meaning I've got nearly 15 lbs at the end to counter just that, let alone a binoviewer, telrad, and finder. I am trying to keep the scope looking clean, without weights stuck all over the place like I have in the past.
What I'm wondering is, If I add a third pulley/spring system inside the rocker box, on the opposite side of another, will it counteract it? If I get a different spring will that not mess up the other two? I'm thinking if I add a third, in a setup where it kicks in when I get below 40 degrees (or normal method) will that simply add to the lack of needed weights? I must say I'm tempted b/c I really don't want to stack to ugly 5 lb weights on the underside of the scope, and I must admit that the pulley system looks quite neat, and is totally silent.
Guy
Guy
Denk II w/nags junkie
