One purpose of a telescope tube is to eliminate all flex so that when a telescope is collimated, it is collimated no matter where it points. However, I know that this can be a difficult job.
We just set up a newly reconstructed Truss tube dob. It is a 22 inch F 5.
When collimated in a down position (a few degrees above horizon), the laser spot is dead on. When you crank it up to zenith, the spot is maybe 1/8 inch from center.
I've inspected for the obvious things, mainly loose parts I suppose.
Is this within spec? Is there any margin for error? Is it a problem with big truss tube dobs?
What is your advice. And where should I look to make it better?
