Wizard Nebula
How to attach those triangles in a mirror cell?
Started by gy60356, 07/29/2003 02:55PM
Posted 07/29/2003 02:55PM Opening Post
Forum Member
Hello,
I am working on a 12.5" scope. I bought a University optics mirror cell but not quite satisfied. I am planing to turn it into a 9 point floating cell. But How should I attach those triangles to the frame? Just use a screw to bolt it down with a nut in between?
Gu
Posted 07/29/2003 03:27PM #1
Yu, what is the thickness of your mirror? If it is at least 2", maybe even 1.75", I wouldn't bother. You will never be able to measure any difference, much less see it.
If, however, it is a 1" thick plate glass variety, the 9 pt. may indeed help. Get a copy of the book by Kreige and Berry, Building a Dobsonian Telescope. They have some excellent pics and descriptions on multi point cells and how to put them together. Their descriptions will probably be all you need to make a successful mod to the UO cell. The key is that the triangle is able to "float" on the mounting/adjustment point without binding. That would introduce uneven "stress" and cause potential flexure of the glass. Not good!
Walt
Posted 07/31/2003 12:12PM #2
Here is a chart of support calculations By Mark Holm using an FEM program called "PLOP". You will see that even a properly configured three point support cell is just adequate for your mirror specs.
http://www.telerama.com/~mdholm/atm/cells/index.html
