Iris Nebula
how to make a sunspotter telescope?
Started by alvarogaray, 08/10/2004 02:34PM
Posted 08/10/2004 02:34PM Opening Post
Hello !
Does someone know how to build a sunspotter telescope? I saw it on the internet, but it is very expensive $325.
thanks,
Alvaro
Posted 08/10/2004 05:43PM | Edited 08/10/2004 05:44PM #1
I assume you are wanting this to use with your scope for aligning it with the sun?
I built mine this way.
I used a piece of PVC tubing and one pipe cap. I cut a piece 10" long and put the cap on one end. Cut another 4" long and sliced it lengthwise. The tube was cut at the closed end of the cap 1/3 the way though and then a 45° angle to meet the cut was made in the tube and through the cap. This left an opening to the out side of the tube so you could see inside. I then attached the slide piece to the tube with pop rivets. This piece of sliced tubing slides into the dovetail that holds my finder scope and holds the finder in place. When the tube is aligned with the sun it shows a round disk at the cap that you can see through the cut. It will not be a disk until it is exactly pointed at the sun.
I left mine white in color. You could make it with black plastic pipe too.
It works very well and looks good actually.
Hope this is what you are looking for and I will post a picture of it if you are interested.
Floyd
Posted 08/10/2004 10:55PM #2
Alvaro,
Just grind and polish a very long focal length lens say 50 to 80 feet, mount it on a board and use a diagonal mirror to feed the sun into it. See May S&T.
Ed
EL Jones's attachment for post 82059
Posted 08/11/2004 12:26AM #3
Sunspotters are harder to make than they look, but if you are handy, you should be able to make one. I never have, but studied a few real hard to learn their secets. What I plan to do is the following:
Disassemble a department Store Refractor
Find a few good flats (maybe parts of an old diagonal).
Get a good medium focal length eyepiece without too many elements.
Build a frame that can be pointed as needed. Make sure you have a way to adjust the eyepiece up or down between the last reflection and the viewing screen (a reflective surface). (The length of the lights travel from the lens to the first reflection, to the second (and third, if you like), and the eyepiece should be as long as the original tube of the refractor)
Mount the optics (diagonals, etc.) all in the right place so that they bounce the light where it belongs, then through the eyepiece, and down to a clean white surface.
Of course, this is all theory. I have not actually built it.
Posted 08/11/2004 02:35PM #4
Scopestuff has a "Solarscape" that appears to use rather different optics and cheaper construction to achieve a similar result for $99. I have not used either and can't say how their images compare.
Posted 08/11/2004 07:15PM #5
If the digital camera was working right now I could show you a picture of mine. I used 2 1/4-20 threaded rods and mounted a clipboard about 10" away from the eyepiece on an Orion 60mm f15 EQ scope. I use a 12.5mm Plossl, for 72x, which seems to be about right. I did velcro 5 large (4oz) nails to the objective end for ballance. This one tracks. The local college has one of those nifty triangular sun-spotter scopes. They are pretty slick, but don't track, so you are always shifting it. Since I got the scope as a "second", the whole project, with eyepiece and drive was only ~$150. Hope this helps.
Charlie
Darkness - typically 6.5+
Focus - JMI Smart focus
