Hurst motor repair or replacement
Started by Bill Guinn, 12/03/2004 03:58AM
Posted 12/03/2004 03:58AM Opening Post
I have a "new" byers 9" drive with a 1/2RPM Hurst MOdel A synchronous motor (P/N 3002-025). Though its truly new, for some reason the motor does not rotate, though it does vibrate so something internally is rotating. After taking apart the gear train it looks fine, free turning etc. So I think something is wrong with the "motor" portion only. The "motor" portion is not readily taken apart - or so it looks that way.
Given the very high cost of replacing this rare motor ($135) and 6 week order time, I wonder if there is not a couple of much cheaper options. First, I assume that someone might be able to fix it. Anyone know who could?
Second, I assume the "motor" portion of a 1/2 RPM motor is the same as a 2 RPM and 4 RPM etc. in the same Hurst series and that the only difference between these motors is the gear reduction. Given that 2 and 4 RPM motors are readily available and significantly cheaper (by > $100) could I buy one and just swap gear trains?
Third, is there a suitable replacement?
thanks in advance
Posted 12/03/2004 04:08AM #1
Have you tried replacing the capacitor? A bad capacitor can cause the kind of problem you are seeing.
Posted 12/03/2004 04:26AM #2
Is this the Synchron motors now made by Hansen?
If so, I can provide some info on this.
Brian
