VDB 142 Elephant Trunk HOO
Image Bounce with stepper motors
Started by Walter, 06/17/2004 01:06AM
Posted 06/17/2004 01:06AM Opening Post
I just finished modifying a second TAL-2 mount with a set of the Losmandy G-11 Digital drives. These use Hurst stepper motors and I had to have Losmandy change the crystal and chip so it would work with my 180 tooth worm. First light a few days ago had a pretty severe image "bounce" that was visible at even the lowest powers. My counterweight was marginally too heavy with the ota I was using, so I made up a slightly lighter set but tonight the image bounce is still there. I can put my fingers on the end of the worm shaft and you can feel the pulses and when you look through the eyepiece, they are beating in unison with the image.
On my first mount that I modified (another TAL-2), I used a Celestron CI-700 drive that uses a different set of steppers and there is absolutely no bounce even at very high powers. They are both being pulsed at the same rate so I am wondering why the difference.
Any comments??
Walt
Posted 06/17/2004 02:29PM #1
Sounds like the stepper is wired incorrectly. If one of the leads is loose you can get the motor to still step, but it will make a noticeable "ticking" sound and move in fewer, bigger jumps. This happened to me a few years ago when a pet rabbit managed to chew through one of the motor wires.... The same thing can happen if the right pair of wires are reversed - it will do a "half-step" back, then jump 1.5 step forward.
Check the wiring diagram and make sure it is being driven properly. Also, make sure the driver chip is compatible with the motor.
Jarad
