Kydex Alternative Wanted
Started by stuper1, 11/04/2002 10:53PM
Posted 11/04/2002 10:53PM Opening Post
I am making a light baffle to place across from the focuser on the secondary ring (it's not a cage, just a single ring). Kriege and Berry suggest using Kydex. Does anyone have a suggestion for an alternative material that will work as well and maybe be easier to find? Thanks.
Posted 11/05/2002 07:12AM #1
Stuart,
I made a baffle using black ripstop nylon. It is very lightweight. For support I sewed in some 1/8" bamboo-like reeds. The whole thing weighs almost nothing and when I'm done for the night it rolls up into a very thin tube that fits into my eyepiece case.
Doug Tanaka
Posted 11/05/2002 01:20PM #2
Stuart,
Your local auto upholstery supply store (there is one in the nearest big town) will have waterproof pasteboard, and various plastic materials that will do the job. There is a vinyl/foam combination material that holds its shape, but can be form fitted. Sorry, I do not know what it is called, but you will find it if you spend a few minutes wandering through the store.
