Well, maybe I should offer up what I have done in the past. I thought it was a bit make shift and wouldn't be acceptable for a long term situation so I didn't bother to mention it right off. However, after reading some of the suggestions, I guess that perhaps about anything will work. I'm just trying to do this right and do as close to a professional job as possible. Now, the lens in question has foil spacers already stuck to the back element and I don't plan on messing with them. All that needs to be done is to add some sort of adhesive to the surfaces of the three spacers to replace what has been cleaned away.
Now, here it is: in the past I have used (don't laugh) YooHoo glue stick, just a dab, applied to the center of the spacers. When the crown elemnet is precisely placed over the bottom element (without turning one in relation to the other, etc.) the glue adhesive naturally spreads out and, if perfectly place to begin with, doesn't make a mess, just stays within the area of the tiny spacers. This glue stick stuff is very clear, water soluble and acid free. After initially applying dab of glue, I flatten it on the spacer just a bit, then let it air dry. It remains just tacky enough to hold lenses together with pressure of retaining ring.
One of my concerns with the sticky material of choice and, for that matter, the home spun materials used for spacers, should you need it, is the extra thickness that results from, say, the adhesive. The good thing about this glue stick stuff is that it creates a variable spacing if you press harder, etc. There seems to be enough "give" that you can achieve a good spacing when the retaining ring is tightened down sufficiently.
Still, if I had to describe what the sticky material on foil spacers is like (the stuff that is on them to begin with) it seems very much like rubber cement. How about that? Does a dab of rubber cement sound right? If anyone knows anything about this and thinks that it would be a bad idea, please say something! In fact, the stuff really DOES seem to be like a tiny bit of Testors rubber cement since it is extremely difficult to clean off. Alcohol with a drop of soap in distilled water is what I used to clean it off,,, with lots of work.
I did all this to begin with for several reasons, one being that the (original?) adhesive was spread well off the area of the three spacers, kind of messy looking and had attracted dark, or discolored dirt (now, how did that get in there?). Furthermore, the lens appears to be a bit overcorrected. I'm thinking that respacing in the process will do this lens some good. At least affect a change in one way or another, and go from there.
