I'm building a 8" F7 dobsonian telescope, and the time has come to make the altitude rings. The mirror box/cell for this scope is made of solid aluminum blocks and weighs about 15-20lbs without the mirror. Thats a good thing though, I like things that are overbuilt. I could easily router up some plywood altitude rings, but I think wood would be out of place in this project.
So I can think of two ways to go about making aluminum altitude rings:
1. I could buy a 12"x12"x.5" plate of aluminum, and use a router to cut a 12" dia. disk that I could cut into two semi circles for each side of the mirror box.
2. I could buy two 1"x1"x24" bars of aluminum and somehow bend them into semicircle rails that could be bolted to either side of the mirror box.
Which method would you choose? Is it reasonable to think that I could bend a 1"x1" bar of aluminum into a 16" diameter ring without some special bar-bending machine?
