Mark Eby
M33 Triangulum Galaxy
Mirror cell for 17.5 inch f/4.5
Started by AstroJack, 06/10/2009 06:12PM
Posted 06/10/2009 06:12PM Opening Post
Hi all,
I have been trying to use Plop to figure out a mirror cell for my 17.5" mirror. I am debating between a 6 point, 9 point and 18 point cell.
mirror diameter = 444mm
fl = 2000mm
Secondary = 80mm
Mirror thickness = approx. 38mm
Can anyone help me understand what plop is trying to tell me?
It looks like the 6 point cell is better than a 9 point cell, but the 18 point is better yet, as I would expect. But is the 6 point cell good enough?
Thoughts?
Posted 06/10/2009 09:42PM | Edited 06/10/2009 09:47PM #1
The author of PLOP considers an rms error less than 4.3e-06 as being sufficient for most optics. Six points of support will work okay, whether it be Pyrex or plate. If that is a Coulter mirror with the original figure, then I am absolutely sure six points will do.
Mark Holm has done an extensive workup of different size examples and uses 2.5e-06 as a cutoff for acceptability. His work considers support for fine figured optics and can be viewed at:
http://www.atmsite.org/contrib/Holm/Plop_optimized_cells/index.html
