Mirror fan installed on the 12.5" DOB
Started by fblue, 02/25/2004 01:57AM
Posted 02/25/2004 01:57AM Opening Post
I took the mirror out today and installed a 3.5" 14cfm fan below the mirror in the mirror cell. It blows very well and does curl up over the edge of the mirror.
I did not install a mirror to blow across the top of the mirror, because the mirror box is a little smaller than the 15" and the same method will not work.
I may install a second fan later, but I will try it for now and see how well it works.
I also cleaned the primary with acetone and got a lot of the spots and specks off the surface without any damage to the coatings. Maybe got 85-90% of them off. Some were just not effected by the acetone. It looks much better now and is deffinately more reflective and clear looking.
I found that the bolts for the mirror clips were touching the primary and holding it tight! Pinched optics! Not good, so I put another washer on the bolt and got the mirror free floating. :^) I hope this helps with the images too. I suspect it will improve them.
Now I need another night to try it out and see how long it takes to cool down.
One other benifit was the battery for the fan took the place of a wieght I added for balance with the 20mm and 31mm Naglers. Dual purpose is always nice.
Hope you all have better weather than we have predicted for the next few days.
Floyd
