Hi, all, I'm working on a 6" f/4.5 mirror. All polished out, attempting to figure.
The mirror has a large and deep central depression, roughly 3.5" in diameter. It's left over from an earlier attempt to parabolize with a too-hard lap (too much overhang, long strokes, hard lap, result - dug a deep hole). The outer zones are relatively flat.
What is the best way to eliminate it? Some books say stick with 1/3 diameter center over center strokes, with mirror on top, and eventually it will work itself out. Others say it's best to use a deformed lap, depressing the central facets using a circle of waxed paper a little smaller than the depression while pressing. I want to concentrate the action in the outer zones, but I don't want to create some other defect that will make matters worse, like turning the edge.
Any ideas?
Doug
Any ideas?
Doug
