More Cooling Fans
Started by Kevin Beebe, 04/22/2008 07:48PM
Posted 04/22/2008 07:48PM Opening Post
I'm a little late, but I was catching up on my reading. The discussion on cooling fans was really interesting, especially since I need to make some changes to my setup. Has anyone tried using a computer slot fan to scrub the front surface of their mirror? It wouldn't work for a closed tube, but I was thinking it would work well for a truss tube scope. Here's an example of what I'm talking about.
http://www.outletpc.com/c1618.html
It has ball bearings instead of sleeve bearings and moves over 31 CFM of air. It might be a little noisy, though. I was thinking of putting these in 2 corners and aiming across the mirror, or maybe I could put one in all 4 corners and set them so they would "swirl"
Any ideas? Thanks,
Kevin
Posted 04/22/2008 11:08PM #1
I used one of those for a scrubbing fan. It worked fine, but was no easier to install or mount for my system. If you can fit them in nicely and have them set to blow the right direction, they can be useful.
