Mark Eby
M33 Triangulum Galaxy
More on trusses >> 4th power with diameter
Started by samg74, 01/20/2004 04:01AM
Posted 01/20/2004 04:01AM Opening Post
"... (resistance to torsional bending) the second moment of
inertia of the individual truss members...which is the ability of the truss tube to resist bending/flexing.
(Second moment of inertia scales with the 4th power of the
radius. Boost your tube diameter by 50% and you get a tube
that is (1.5 ^ 4) 5.06 times stiffer!...yet this is not
reflected in (most ATM design books)"
< < Tom Krajci
< < Tashkent, Uzbekistan
< < -- the ATM list from a posting in 1994 --
Key point is the 4th power resistance to bending.
Trusses should be wider, not heavier. By far.
Compression is not significant after cool down. So design maybe should be aimed at vibration damping.
Posted 01/21/2004 12:49AM #1
Right--larger diameter, not thicker wall.
