Hi all:
I recently finished assembling a dedicated 80mm Ha refractor. I didn't exactly "make" my new solar rig in that I didn't grind the lens or cleave the mica... But I did assemble everything from a diverse collection of parts. The project took a lot of planning because I wanted to be able to view the whole solar disk at low power and also have enough aperture to zoom in on a solar feature when desired. Also, the focal plane has to be located in just the right spot with a rear mounted Ha filter to avoid using extension tubes before the telecentric lens assembly.
This project has been on and off the front burner for a couple of years. At least since the last Mercury transit which I observed with a PST. The parts list is as follows:
- Solar Spectrum 0.3A rear mounted Ha filter with 25mm clear aperture.
- Baader 90mm DERF. This is mounted in a cell I machined in my basement from a Stellarvue screw on objective cap. The DERF cell is the one part I actually made myself.
- Baader 4x telecentric lens.
- Stellarvue 90mm OD tube, dewshield, and rings. The tube was originally for a SV 80/9D. Vic Maris was kind enough to discuss this project with me over the phone and sell me the tube, dewshield, cap rings and various flanges without any optics. The 80/9D tube was slightly too long, but easily shortened. With this system, the actual focal plane is only about 3/4" behind the back of the focuser when it is fully racked in, so a Nighthawk or William Optics f6 tube would have been a few inches too short.
- William Optics 80mm f6.9 fluorite doublet. I've had this lens for quite a while. It was once sold as an upgrade for 80mm achros.
- Moonlite focuser. I am really tickled with this focuser. It is sturdy enough to support the whole telecentric, filter, bino assembly or a camera without any noticeable sag.
The focal length of the system with the 4x telecentric lens is such that a full solar disk image with prominences is about 20mm in diameter at the image plane. The entire solar image will thus fit through the filter and binoviewer for an unvignetted full disk view. The solar scope takes magnification very well. With binos, the view is simply amazing.
This first photo is the whole system at first light, a few weeks ago.
Jim
Jim
