New Teflon Bearings
Started by fblue, 12/16/2005 02:47AM
Posted 12/16/2005 02:47AM | Edited 12/16/2005 02:48AM Opening Post
Ok, I decided to try something completely different! 8) My new replacement scope in the works and I am trying to come up with the optimum set up this time. I am trying to eliminate vibration and duration of vibration, smoothness of motion and rigidity of structure.
There have been some comments about the rocker box and its contribution to these problems. Some articles I read dealt with the fact that the Teflon pads ride on a small area of the bottom of the rocker box which causes the loads to be uneven and perhaps flex the board itself. Also stability was said to be compromised somewhat by this spacing of the pads and the small area of contact.
So I decided to make a new style of Teflon Pad to work with a round flat foot design ground board. My thoughts on this was to put the weight load equally on the entire foot and have the pad cover a larger area of the bottom of the rocker box with as little surface area as possible.
I decided on a donut shape for the Teflon bearing bearing that was just under the diameter of the foot. So I made the pads 2.375" in diameter for a 3" foot. I felt the circular shape would distribute the weight more evenly and that it would also give a rounded leading edge in either direction of rotation for a smoother feel.
I also made a 2.375" central plate for the AZ pivot bolt . This I had read would help with distribution of the weight and also make the box more stable and dampen faster, with the added benefit of smoother motion. So I am trying this as well.
Here is a picture of the Teflon Bearings that I made.
What do your think?
They have less of a load per square inch than is normally used, but I have not had a problem when I used less load per inch in the past. Load is about 6.5 lbs per square inch on the 3 pads.
fblue's attachment for post 28668
Posted 12/22/2005 02:36AM #1
Wow, I can not believe the numbers of these bearings that are being ordered. I never really meant to make them for sale! Oh well, make what the public wants! grin
