NEWT guru needed?
Started by Buck8one2, 05/27/2007 01:44PM
Posted 05/27/2007 01:44PM Opening Post
Hello folks
For the better part of a week now I've been trying to determine if I could use or need a larger secondary in my scope. After carefully measureing the various components required for the Newt program I have completely confused myself on the "spare focuser in" measurement. In the help file its says to measure where the field stop is in an eyepiece and from there on it got confusing fast. However, in the NEWWIN file there is what seems to be a very simple sentance to explain it all and it says "Spare Focuser In Travel - the distance from the top of the focuser tube (when racked all the way in) to the focal plane (where the light from the primary mirror comes to a focus)". OK this sounds a lot easier to me since I know my focal length already which is 60.2". So now I place a very soft cloth over the primary mirror and measure up to the middle of the secondary face and I get 51.25" which leaves 8.95", so I carefully measure from the same point on the secondary out through the focuser and this point comes exactly 5/8" or .625" past my racked in focuser. Taking .625" and plugging this into Newt with all the other measurements the program says everything is all right...no red flags. All is good. However when I check the preformance it gives me this:
Afov 100% Illum. is 7.529e-002 deg. and 7.865e-002 dia.
Afov 75% Illum is .8855 deg. and .925" dia.
Whats with this e-002 business? Am I taking the correct measurement for "spare focuse in" component?
I have messed around with this program for a while now and have seen this e-002 before but it has always had a red flag on something that indicates there is an issue. This time I get it and NO red flag issues.
I need a bit of help with the "spare focus in" and whad does the e-002 mean.
Thanks
Buck
Posted 05/27/2007 05:08PM #1
The e-002 is scientific notation, meaning the decimal point should be moved
2 places to the left. This is often used on computers and calculators
instead of displaying a lot of zeros. So written in more normal
fashion the first line would read
Afov 100% Illum. is 0.07529 deg. and 0.07865 dia.
In terms of your scope, this is a rather small but acceptible fully
illuminated field.
I think you are interpreting the "spare in focus" correctly.
0.625" is a reasonable amount and will allow just about all
eyepieces to reach focus.
Some items needing large "in focus" are the TeleVue
Paracorr, the Nagler 31mm Type 5, and Nagler 22mm Type 4.
If you don't plan to use any of these you could reduce the
"spare in focus." For an F6 scope you will not
need the Paracorr. There may be other eyepeice brands that
also need extra "in focus" travel. Maybe some of the
Celestron Ultima line or old University WideScans may need
numbers near 0.5" spare in focus.
Posted 05/27/2007 05:22PM #2
Hi Buck,
I had the same questions when designing my scope. NEWT said I needed a secondary larger than the one I ended up with. I called Brian at Protostar and he said in my 14.5" telescope to go with the 2.6" secondary making sure that I use a low profile focuser and had my lowest power EP just come to focus when the focuser was racked in almost all the way. I have about a 1/4" of in focus left just in case I ever get a 31T5. wink I've noticed no light loss at the edges of my 26T5.
Call Brian at Protostar and see what he has to say about your example.
