I have a Nikon Binoviewer, a conversion from a microscope head no doubt. I want to use it with a truss tube Newtonian reflector, and will need to cut down the length of the truss tubes to reach focus. I would like to use it without the usual 2X or 3X Barlow that kicks the magnification up so high. Does anyone have experience doing this? Any idea how much I'll have to cut my tubes down? how about link to a diagram of a typical light path inside a bino-head? Astrosystems sells a kit that lets you cut the tubes down, for binowiewing, then add back in the amount of tube length removed for use with the usual collection of 2" eyepieces. If I assemble by scope just right, I can just barely reach focus with the cell of a Meade #140 Barlow screwed into the Nikon Binoviewer. I want to take the Barlow out of the picture.
Nikon Binoviewer light path length?
Started by cookndad, 11/08/2002 04:45AM
Posted 11/08/2002 04:45AM
Opening Post
Posted 11/08/2002 07:00AM
#1
Hi Richard.
Depends on the particular binocular head and its body structure/configuration, but I'd figure the optical path (from seat/base of head to top of eyepiece collars) is likely about 5 inches. That's usually a reasonable "starting point" for most modern microscope bino heads.
Is your Nikon a Siedentopf design (true binocular-style hinged head), or is it an older "flat" design?
If you have (or have access to) a refractor with which the head *can* reach focus with a given eyepiece, you can focus that head/eyepiece combo, note that focus position on the drawtube (where it meets the rear of the focuser housing -- use pencil or a bit of masking tape), then remove the head from the configuration and re-focus that same eyepiece, straight through and note *that* focus point on the drawtube (remember to focus on the same target, or at infinity, in each case). The distance between those two marks on the drawtube will be equivalent to the length of the head's optical path.
Hope that helps a bit.
Best wishes and luck.
-Dan
-Dan
Funding Member
