Wizard Nebula
On-board 12v DC Battery?
Started by toml, 04/08/2004 08:23PM
Posted 04/08/2004 08:23PM Opening Post
What are people using for an on-board 12V DC source. I'd like not to carry a car battery powerpack, and just have a small-medium sized cell doubling as dob counterweight, but not weight 10 pounds either if you follow.
I was eyeing some of my cordless drill batteries. These can often be found cheap ($10 for 9.6 or 14.4V ones, but harder to find 12V ones). However, these don't often list amp-hours on them just voltage. A few do though, and they tend to range between 1.7Ah and 2.4Ah.
Considering that 8 (or 9 I guess since rechargables are 1.2V not 1.5V like alkeline) AA rechargeables in series will make for a 12V source, and each one is listed at 2100 mAh (ie. 2.1 Ah) it's harldy any benifit to having a bigger drill battery. I've seen some square "hobby batteries" (like at radio shack) that cost more, but are 12V, though I don't see any rechargers sold for them? Basically those look like miniature car batteries.
I would like to find something with slightly more Ah, like say 4Ah that isn't one of those big heavy portapower packs (I have one btw), rather something I can leave on-board on the dob so I don't have to carry yet another item with me. Motors (fans) eat lots of power though, so maybe its unavoidable?
TomL
Posted 04/08/2004 09:46PM #1
I use a gell cell sealed 12 volt battery for both of my DOBs. One is 1.5 (1.5 Amp hr)lbs and the other is about 3 lbs (3amp hr)and I use the 1.5 lb for a counter wieght on the smaller scope as you plan to do.
I bought them locally for $18 and $25 each. Call around and ask for them. They come in many sizes, shapes and wieghts.
http://www.ibsa.com/estore/search.asp?N=44+4294813338&Ntx=&Ntk=&Ntt=&Ns=product+Type%7c0&Nu=Part+Number&mscssid=4TNUXV1G0E089NEQ9EHTJC11NHP673QF&js=1 Here is a site that has 4 amp sealed batteries like those I bought. This is the same brand I got in the 3 amp.
Floyd
fblue's attachment for post 78443
Posted 04/09/2004 11:48PM #2
How about the 12 volt batteries they use to power kids toy jeeps.
They are only about 6" wide and about 4" high. You should get
pretty good mileage out of a charge. I don't think they weigh much.
Later
Ed DeMarco…………….
Posted 04/10/2004 12:39PM #3
Tom, I use a 7 AH 12V lead-acid gel cell on board my 13" dob. I use it to power two 12v computer fans, plus about three watts worth of dew control. It will power everything all night if I need it to.
I've seen them in hobby stores that carry R/C stuff. It's about three inches by eight inches by about 4 inches high. Only weighs a couple pounds.
One thing to be careful of with gel cells is overcharging. I burned out two with a one amp trickle charger before I switched to a charger with automatic turn-off.
Good luck,
Doug
