Hi folks,
I've been using a cats-eye (triangular center spot) for collimating a short-barrel reflector. Seems like a good system worth keeping as I build a new longer (64 inch) focal length OTA. The new OTA barrel is too long for my arm to reach to the end of the OTA while looking into the focuser.
I've been looking for an example to copy or at least understand of a long-ish reflector OTA and mirror cell designed so that the person looking into the focuser can still adjust the collimation screws.
I'm thinking that I want to run threaded rods along the outside of the barrel back to the mirror cell so that I can twiddle the mirror collimation while looking into the focuser. Doing so puts the tension springs and hardware outside of the barrel as well. This feels a little strange and leads to a custom mirror mount. I'm prepared to do this, but I wonder if I'm going down the wrong road.
But sticking a metal alignment tool down the inside of the OTA barrel (in the dark) to adjust screws alongside the mirror feels like poor practice to design in. I suppose I could permanently mount three threaded rods running down the inside of the barrel that are held in place by baffles. But this just puts thermal mass inside the barrel. I've just not seen any knurled knobs sticking out of the front ends of OTAs so there must be a few people that thought this wasn't a good idea.
So can you point me to a few places for examples of one-person collimation design on a reflector OTA longer than a normal person's arms length.
None of the above feels like a "keep it simple" approach to a simple problem lots of people should experience. Do I just need a different collimation method/tool so that the OTA is simple and straightforward.
Thanks in advance for the help.
