Painting over Polyurethane
Started by Walter, 12/06/2003 01:35AM
Posted 12/06/2003 01:35AM Opening Post
I am redoing the tube for my 10" f/6 dob with a new sonotube. I have coated it with numerous coats of polyurethane to seal it, but want to paint with a durable paint. In the past I have had a terrible time getting paints, especially latex, to adhere properly to the poly, even after sanding completely. Any suggestions from the paint pros out there. I do not have access to a spray painter so I need suggestions for brush and/or spray cans.
Walt
Posted 12/06/2003 02:44AM #1
I think you might be better off just to continue wiith color of your choice in polyurethane.
Posted 12/06/2003 07:32AM #2
Hi Walter,
I honestly don't know, but wouldn't think it would work well off-hand. Polyurethane itself is very durable, especially after several coats are applied. As mentioned a little earlier this week, you can add stain to make it different colors. I've even "ebonized" it by adding black dye stain with wonderful results--like a black lacquer piano.
You can lay down several coats with only a brush or pad, sanding it flat and to remove the dust nibs, runs and sags after each coat, then spray only the final coat to get a smooth, brushless surface. That way you don't have to buy $200 worth of polyurethane in spray cans. I also recommend gloss polyurethane for all but the last coat, which I generally do in satin.
To summarize, I'd buy a 1 gallon can of gloss polyurethane, add a stain to color if you wish, and apply several coats, sanding as close to flat as you can between each one. (I do at least 6 coats before I begin to see a nice flat and regular overall surface begin to emerge). Then do a final sanding (I generally use 320 or 400 grit for the final sanding) and spray the last coat using satin from cans. For an 8" or 10" like the ones I make, it would take about 4 cans. So that would add up to $20 for the gallon of gloss and probably $24 for the four cans of satin. You can see why it quickly becomes worth it to buy a compressor and finish gun if you are going to do this a lot.
Good luck!
Lee
Posted 12/08/2003 01:51PM #3
Walter, Krylon makes an oil-based polyurethane brush-on enamel. I use it on my sonotube newts and it's near impervious to moisture, and very durable. (I've always put it directly on the tube exterior without sealing first.) It's getting hard to find, but it's still on the Krylon web site so I assume they still make it. If you can't find any at your local stores (I found some at Wal-Mart of all places), then you should be able to order some through a paint store.
Good luck,
Doug Scobel
