Iris Nebula
Power to a secondary heater
Started by eyork, 12/28/2004 10:27PM
Posted 12/28/2004 10:27PM | Edited 12/28/2004 10:28PM Opening Post
If I am trying to send power to a secondary heater on a truss dob, can I route wires to the pole connectors on each end?. I am assuming the aluminum truss poles should carry the current quite well.
Is this correct? Is there a better way?
Ed
Posted 12/29/2004 01:27PM | Edited 12/29/2004 01:27PM #1
Aluminum is an excellent conductor so that should work, but I'm not sure whether a shroud that's damp from dew could cause a short circuit. Anyone have experience in this?
Posted 12/29/2004 03:34PM | Edited 12/29/2004 03:34PM #2
I would recommend running an insulated wire through the center of the truss. You can have a connector sticking out near each end. I would worry about shorts and giving myself little zaps running it through a bare aluminum pole, unless you put some kind of insulating wrap around the rest of the pole except where the connection are.
If you want to use the spiders to carry the current to the secondary mirror, just make sure that the rest of the spider is painted to it isn't going to short either (or use one of the Protostar units - their spiders are coated with something non-conductive to prevent this problem).
Jarad
