Ruben Tommasi
Andromeda Galaxy (M31)
Primary baffle tube, installing spiders squarely
Started by macdonjh, 09/09/2014 07:35PM
Posted 09/09/2014 07:35PM Opening Post
I have two questions for the knowledgeable people here:
1: What is the best way to determine the proper length of the primary baffle tube for a Cassegrain telescope? I don't have any design software, so I hope there is a geometric or analytic solution that can be done with a piece of paper, pencil and calculator.
2: What is the best way to locate four points on the circumference of a circle that are 90 degrees apart? I tried one method that didn't work well when installing the spider in my scope. Note that I do not have a machine shop, I'll be working with basic hand tools.
Posted 09/09/2014 11:54PM #1
1. Full scale drawing with ray traces drawn out. Then make measurements.
2. Wrap the tube with newspaper taped together to get a full circumference cover. Mark the paper at one point, i.e., the top. Remove the paper and measure the circumference and measure/mark the 1/4 distance points. Return to the tube and transfer measured points to the tube. Drill holes.
Walt
