Hi,
I will be receiving a 7 1/8" OD .083 X 40" formed and welded aluminum tube from a local fabricator for my 6"f6 home made scope, to replace my old home-made fiberglass tube.
I want to paint the inside with Krylon Ultra-flat Black #1602 paint and the outside with another Krylon Paint, probably a high gloss white.
I do wish to ensure the best bonding, and Preston Engebretson had recommended a Phosphoric Acid wash, then a primer.
I have some Phosphoric Acid used to wash Teak, as part of a Teak Cleaner with a separate Sodium Hyroxide rinse - will that Acid be OK?
WHAT PRIMER should I use for these products?
I have painted aluminum in the past and was NEVER totally successful. They peeled and flaked, usually.
All help from successful aluminum painters would be appreciated.
Also, if anyone could get Preston Engebretson to drop an e-mail to me at [email protected], that would also be good.
Thanks all.
Mike.....>
Thanks all.
Mike.....>
