Jay Messeroff
Lunar & Solar Transits
Question for Rick and Vlad (Diagonals!)
Started by Walter, 06/03/2004 02:09AM
Posted 06/03/2004 02:09AM Opening Post
Hey guru's smile
I was thinking as I was pushing glass today. (Dangerous wink ) If I get a good figure on my mirror so that I am pretty confident that when I put it in the scope it will give the "classic" straight ronchi lines when focused on a star, won't any diagonal problems surface as deviations in the ronchi lines when it is actually star tested in an ota?
In all my years of making scopes, I have never actually encountered a defective diagonal to the point that I knew it was inferior and had to replace it, and I have not always bought "high end" stuff.
Walt
Posted 06/04/2004 02:18AM #1
Walter, there are only three types of wavefront errors that can result from
the diagonal. One is astigmatism, caused by a smoothly distributed error
across the diagonal. The next is wavefront roughness, caused by diagonal's surface roughness, and the last is turned edge.
Astigmatism is the one most feared, for no good reason. I did some calculations, which also fairly well agree with empirical testings I'm aware of, and it shows that astigmatism induced by any given smooth surface error on the diagonal, is about 70% as large on the wavefront. That means, diagonal with only 1/8 wave surface error of this kind would induce not more than 1/11 wave of astigmatism (which compares to 1/17 wave of spherical aberration contrast-wise). And that is assuming diagonal not wider than the converging light cone. Since the diagonal is most often somewhat larger, it induces even less of astigmatism with this type of surface error.
Surface roughness can be more of a problem, because every surface irregularity magnifies 2x on average in the wavefront. So 1/8 wave surface diagonal with this type of error would actually cause ~1/4 wave wavefront roughness error.
Finally, turned edge is more of a problem with minimized diagonals, which are only slightly larger than the converging cone. In such case, the effect is roughly similar to that of the primary's TE.
Astigmatism is not likely to be seen with the Ronchi test at all. Roughness and turned edge may be seen if they are significant, and if test has sufficient sensitivity (this especially applies to fast systems; a good Barlow lens is necessary to multiply the test sensitivity). If nothing can be seen, other than known pattern of the primary, that indicates that diagonal is not bad, but still doesn't guarantee it is a high-quality surface.
