Micheal, Very nice overall design. You might want to look at "Reflecting Telescope Optics II" by R N Wilson pages 259-272 have quite an indepth and current discussion on edge support and the requirements.
I believe that your current setup is similar to Schwesinger's case "e" page 265 where the support is discribed as follows
V-support: The astigmatic mode disappears if the angle 2e=90 degree. Thus the right-angled V-support is almost optimum and gives a big improvement over a pure edge support).
However, I would look closely at you supports contact points close to the mirrors surface. From the research presented in the above referance, it concludes that support should come from the center of the edge in mirrors with f ratios greater than about 3.
Very nice workmanship...Keep it up.
Best Regards Preston
