The Formica can be used on a round bearing. It can be undercut or sanded thinner or heated to allow it to be wrapped around.
Once it is cut into the thin strip, it is much more flexible.
Also you could use a textured material that is used for tub enclosers. It is usually found in white and at most any home improvement store..
Another alternative is ABS textured 1/16" that is available at most plastic supply stores.
