Now that I have my tube material for the scope I am in the process of building, has anyone out there had any luck in re-coating their own objective lens? And if you have, what chemicals are involved, and are they readily available. And did you have good luck in doing so? Any advice is most appreciative. Thanks :S
Re-coating objective lens
Started by nzdmmf, 03/17/2006 05:56PM
Posted 03/17/2006 05:56PM
Opening Post
Posted 03/17/2006 06:29PM
#2
Let me explain a little further, Terry.
The process generally used for coatings is the depositing of metal compounds in a high vacuum chamber. The coating materials are vaporized and then they condense on the glass surface(s). The procedure is usually done under very high temperatures.
Larry
Larry
Posted 03/17/2006 06:35PM
#3
Before you can recoat a lens, you will first have to remove the original coating. There have been a number of threads on these forums regarding the stripping of damaged coatings on lenses. Typically you would have to grind off the old coating and repolish and refigure the glass surfaces. It's not a simple task. If you can find an easier method, folks would like to hear about it.
clear skies,
dan
clear skies,
dan
Funding Member
