Hello:
Welcome to the club. I'm wrapping up a similar project. Probably the most important thing you'll need are the designs for the cassegrain and gregorian, e.g. the mirror separations and back focal distances. I didn't have this and wish I did. I wouldn't recommend trying to make one tube for both a Gregorian and Cassegrain since the position of the secondary mirror is quite different. You'd end up with the Cassegrain secondary mirror at the end of a long rod which probably won't be that stable. Cassegrains like these are VERY sensitive to collimation errors. There isn't that much to gain by having both a Gregorian and Cassegrain since the f/ratios are close. I'd pick one and stick with it. Swapping the secondaries between the Newtonian and Cassegrain mirrors can be done, but you need a way to collimate the scope at night. It will be very hard to make the mirror mounts so stable that you won't need to collimate when you swap the mirrors unless you want to machine kinematic mounts.
As far as parts, you'll need a lot. For starters:
- tube: You can make either a round solid tube or a truss tube. I made a round solid tube since it's easier to attach it to a german mount, and the scope is compact enough that I don't need to disassemble the tube to fit it in the car. To make the round tube, I got a piece of sheet aluminum 1/16" thick, got it rolled into a tube, then riveted it together.
- focuser(s): Any well made focuser will be good. I have ones from Astrosystems and Moonlite. If you want to use both Newtonian and Cassegrain foci, you'll need two focusers. Get a 2" focuser, since you'll want as wide of a field of view as possible with the f/16 or f/24 beams. For that matter, get an eyepiece with as big of a field stop as you can. Your Cassegrain focuser should have a lot of travel.
- spider: I got mine from Astrosystems, and it works quite well. If you want to use a Nazmuth focus with your Cassegrain, you'll need another spider and another diagonal mirror.
- primary mirror cell: Almost any old mirror cell will work, as long as it has a hole in the middle. Make sure it can hold the mirror at all orientations, especially roll angle. I'd recommend a mirror cell from Novak, but I don't think they're in business anymore. The ones from Parks cost an arm and a leg. You can put an add on Astromaart and see what pops up.
- secondary mirror cell(s): For the Newtonian secondary mirror holder, there are a lot of places, such as Astrysystems. For the Cassegrain mirror, you may have to make it on your own. The article on CloudyNights describes this.
- Back end plate: Connects the primary mirror cell to the tube. I fabricated by own from 3/4" plywood.
- Mount: For the cassegrain configuration, I'd recommend a german mount or making a dobsonian on a tracking platform and a Nazmuth focus. There was recently a very good article on CloudyNights with a scoope like that. You definately want something that tracks. I was using my 12.5" f/15 cass without tracking, and it was a major pain. For my scope, I got a G-11 mount. But watch the weight, since the G-11 can only hold 60 lbs, and a 12.5" Cassegrain can easily exceed this.
I found that putting the scope together takes alittle trial and error, especially with the Cassegrain. The backfocal distance is proportional to the primary to secondary mirror separation and the square of the secondary mirror magnification, if I recall correctly. A shift of 1/32" in the secondary mirror position will have quite a noticable effect in where the focus is, so you'll need to have a way to shim the secondary mirror position to get the focal point to be within the range of your focuser. I put the spider a little farther back than necessary, then put washers behind the secondary mirror holder until the focus was where I wanted it. The mirrors were made for a specific separation, so you should build the scope to that design or else you'll have spherical aberration.
Cheers
Mike Connelley
Cheers
Mike Connelley
