Philip Imbrogno
Elephant Trunk Nebula
Re: Once and for all..........what mirror coating?
Started by fblue, 09/26/2004 05:32PM
Posted 09/26/2004 05:32PM | Edited 09/26/2004 05:33PM Opening Post
Enhanced coatings require high heat to apply them, this is a risk in it's self. If the glass is not annealed well, or has a flaw, it can actually break or change the figure! It is also stated that they warranty only up to the cost of the coating in these cases!
The enhanced coating is thicker, up to 2 wave lengths thick compared to 1-1.5 wave with standard, this is also a risk. There is a greater chance that the coating will not go on completely evenly causing a change in the figure.
Next, the reflectivity is not really that much higher.
The 89% rating for standard is below 450nm and above 650nm between this it is about 92% compared to 95-96% for enhanced. The eye is not sensitive below 450nm or above 650nm. You probably will not see the 3% change. It is also said that enhanced coatings will deteriorate much quicker, I have read as little as 18 months and as long as 36 months before they are actually less reflective than protected aluminum.
I have had talks with many coating companies and the guys that actually do the coating say, "Just do the protected aluminum on the primary".
Floyd
Posted 09/26/2004 06:19PM #1
Diagonals are a different story. With the size of the mirror and the thickness vs. diameter, there is no problem with the enhanced coatings. They can control the application of the coatings much better on a small mirror. Most all the manufacturers that I have talked with state they can do a good job on the diagonal.
The other thing is this. The diagonal has all the light of the primary concentrated on it's smaller surface, so reflectivity and scatter are very important. If the coatings are applied with consistency, then the scatter is good and the reflectivity becomes worthwhile. The quality of the diag is also of great importance. You want as flat a mirror as you can afford. I assume you already have the diag? I had two re coated recently and they came back looking just like new. grin
Floyd
