Hi David,
I chose a 1.83" for best contrast. The primary mirror reflection fits quite well into the surface of the secondary and none is lost at the edge so it is plenty big.
The 2.14" will give a 2x larger 100% illuminated field and 75% illuminated field over the 1.83", but with a larger central obstruction percentage. This would still work well though and might be slightly better on DSO, where the 1.83" would be best for planetary work.
The 2.6" however, is too large and causes vignetting at 75% ray at the aperture and focuser according to Newt. This is not what you want.
So, the 1.83" or the 2.1" would be your best choices. Then it is what are you wanting to do with the scope as far as type of use, visual or photography, planetary or DSO?
