VDB 142 Elephant Trunk HOO
Re: Tripod, Mount, Scope Trolley / Dolly
Started by atracht, 05/19/2005 03:49PM
Posted 05/19/2005 03:49PM Opening Post
Perhaps this will inspire:
http://www.astromart.com/classifieds/details.asp?classified_id=352778
I use JMI Wheely Bars that include leveling feet.
-- allen
Posted 05/20/2005 01:51AM #1
I carry my assembled G11 mount w/ 8" F/6 scope, rotating rings and 44 pounds of counterweight on the Wheely bars. Of course, I only use it on my reasonably level cement driveway.
If I were to want to move it assembled over sloped grass I would worry about several things:
1. The system must be securely fastened down to the dolly so it cannot tip relative to the dolly.
2. The dolly must be large enough so that, at the steepest part of the yard, the center of gravity is within the contact area as defined by the wheels. For me, this would be considerably wider than the feet of my tripod.
3. The wheels must be large enough to move the entire weight over the uneven surface.
4. If the slope is more than a few degrees, then the dolly must have brakes so that it can't run away from me. Ideally, the brakes would automatically be actuated if I let go of their control (dead-man switch).
5. Once I arrive at my observing are I must be able to orient the mount and level it.
1, 2, and 3 don't seem that hard, depending on the slope. I might solve 4 by towing the dolly behind my lawn tractor. I might even use the chassis of a lawn tractor cart as the starting point of the dolly.
Item 5 would be quite difficult with an equitorial mount. In fact, it would seem that all of this would be easire with a Dob and its lower center of gravity.
Perhaps these thoughts are useful.
Good luck,
Allen
