Steve,can you explain further, this is an interesting design. You cut a 2" dowel and inserted into the tube- was it snug? Then you drilled a hole up through the dowel. Then you cut the dowel on a bias to make two wedge shapes? Please explain. Do you mean you cut the dowel inside at an angle and put a t-nut on the top wedge?
Brien
Brien
