REFRACTOR COMA
Started by lancetakiguchi, 12/15/2002 08:02AM
Posted 12/15/2002 08:02AM Opening Post
I have a short f 5.5 refractor that is 127mm that is built from Enlarger lens. Is a f stop the only way to combat coma when looking at planets?
Sincerely,
Miles Takiguchi
Posted 12/21/2002 10:39PM #1
Mayhaps a bit late, But check on the direction of lopsidedness as seen in the out of focus rings. If it is the same on both sides of focus the objective needs collimating. If the bunching flips 180* inside and outside of focus, the lens itself is to blame. Assuming 127mm aperature, this still should be a fine RFT. Ron
