I'm trying to remove a mirror from a starfinder mirror cell. I tried using a hack saw for a while but its a very slow process. Any sugestions?
Removing an epoxyed Meade 12.5" mirror
Started by Finn, 02/07/2004 11:05PM
Posted 02/07/2004 11:05PM
Opening Post
Posted 02/07/2004 11:09PM
#1
Soak the particle board in water until it falls apart was mentioned last time. Maybe that is worth a try. I understood you were going to recoat the mirror, right?
If so, then you could also try the Epoxy remover like i used on a secondary mirror after I had cut it off through the glue. I just soaked the backside in the solution not letting it get on the top side with the coatings.
Floyd
Floyd
Funding Member
Sponsors
- Anacortes Telescope
- BW
- kwtelescope
- APM-Telescopes
- Matsumoto Company
- astronomy-shoppe
- BBLABS LLC
- Waite Research
- CarbonScopeTubes LLC
- AstroMart LLC
- Vernonscope
- Desert Sky Astro Products
- Astromart Customer Service
- SellTelescopes.com
- RemoteSkies.net
- FocusKnobs
View all sponsors
