Mark Eby
M33 Triangulum Galaxy
Sonotube for 12.5 inch DOB
Started by jonisaacs, 09/01/2005 10:32PM
Posted 09/01/2005 10:32PM Opening Post
Hello...
I am considering replacing the rather beat up Sonotube on my 12.5 inch Discovery DOB. The current Sonotube seems to have a wall thickness of about 0.40" while the new stuff I see listed is about 0.20". Certainly the 10 lbs. saved by the thinner walled tube would be welcome but I am concerned that it would not be stiff enough to provide adequate support for the mirror cell, spider, bearings and focuser.
What do you think??
jon
Posted 09/01/2005 10:53PM | Edited 09/01/2005 10:53PM #1
It would work, just make sure you seal it with epoxy paint or urethane paint to make it stiffer. The paint will soak into the paper and add to the strength and stiffness, especially if you use a thin paint vs. a thick one.
I think that you would have no real problems and the .020" that you will lose, .010" on each side, can be taken up with a washer if necessary for the mounting of the cell and spider. But I doubt that it would be required. The rings on the end will protect the Sonotube from harm too. Certainly, I would not throw it around! wink
You can get a replacement tube from Discovery too as another option.
Or the .040" is still available. You are just finding the thinner one because they are used more in that size I would imagine. There is a light wall and a regular wall, the .020 is the light wall as I recall.
Posted 09/04/2005 10:52PM #2
Hey Jon,
You might try looking up some of the construction material wholesalers in your area. We have one in Phoenix that handles a couple of brands of "sonotube". There are different thicknesses and I.D/O.D. treatment. They start from ~6.0 to 36.0". They usually allow you to scroung around for a previously cut piece. They can cut a length for you.
John
Posted 09/06/2005 02:48PM | Edited 09/06/2005 02:52PM #3
Jon, find a genuine "Sonotube", available at real building supply stores. Wall thickness is about 5/16" in the 14" size. My 13 inch Dob uses a 16" Sonotube and it is more than robust enough. It has survived more than eight years of drenching dew with no deterioration.
Use fender washers when mounting the spider. They will distribute the tension force over a larger area and reduce deformation of the tube.
Many folks use the term "Sonotube" rather loosely, but it is a brand name. The "Quiktubes" sold at home improvement stores are not the same thing.
Doug
