A friend of mine is legally blind with a form of macular(spelling) degeneration. He is able to see some from the perifery of both eyes ie: straight ahead vision is gone in both eyes. He can read slowly using a common storebought monocular 10x/21mm (I think).This thing was prescribed to him by an optometrist. The eyelens is very small. I think that something else, even custom made would work much better.Does anyone have any ideas as to what would work more effectively? such as a converted uwa eyepiece or a source for such an item. Any help would be greatly appreciated. Please pass this on if you can.Thanks in advance for your help, Tony
specialized monocular
Started by Tony Ennis, 11/30/2008 03:59PM
Posted 11/30/2008 03:59PM
Opening Post
Posted 12/02/2008 09:07PM
#1
You might want to try a variety of scope eyepieces, turned upside down. I use a flipped over 20mm Plossl when I need high magnification to inspect solder joints (I unscrew the barrel so I can get my eye right up to the field stop).
An inexpensive 2" EP, maybe a 30mm Q70 or the like, would probably give a wider field and more eye relief.
Hope this helps,
Tim
Hope this helps,
Tim
Posted 12/03/2008 11:18PM
#2
These monoculars also need to be small and light-weight,
as they must be carried all the time. A 2 pound scope
built around a big Nagler eyepiece is not going to be
very practical. I expect it will be hard to beat a
small well-made pocket monocular by Zeiss, etc.
http://www.buytelescopes.com/product.aspx?p_id=2257&store_id=#
Funding Member
